SNMP Authentication TrapsNEW!
You can enable/disable SNMP authentication traps that synchronizes changes between the show switch management command and SNMP GET. To enable SNMP authentication traps, use the following command:
enable snmp authentication-traps
To disable SNMP authentication traps, use the following command:
disable snmp authentication-traps
Use the show switch management command to display SNMP authentication trap configuration information.
